jeromeof
Isn’t this basically the WiiM light ?portable speaker + constant power supply, wifi/bluetooth + alarm clock
I corrected the description, it is supposed to be a large speakerIsn’t this basically the WiiM light ?
So do you want a 100W unit running off batteries? That won't run for long at full power.przenośny głośnik + stałe zasilanie, Wi-Fi/Bluetooth + budzik
aimed at a niche market..will just be more expensive without a dac (represents little in the cost)..ironic no?I would like to see a pure streamer without an analogue part, but with a good touch screen from a smartphone, not necessarily high resolution about 7", on which it would be convenient to control playback and presets, so that there would be no need to reach for a smartphone. Or with a simple matrix a screen that will display the name of a song or radio station large and on the body so that you can quickly select 10 presets. Perhaps it should look like a small 7"-8" tablet with an aluminum body with an adjustable angle, something like a Yoga Tablet. a tablet but with a streamer inside and that’s it. Wi:Fi, Ethernet for connecting to the network and an optical output and that’s it. Now there are a lot of active acoustics with digital inputs; they only need a digital streamer, there is no point in spending money on the analog part and analog connectors.
Nowadays it's hard to find an audio device that doesn't have a DAC!aimed at a niche market..will just be more expensive without a dac (represents little in the cost)..ironic no?
I imagine that wiim can especially wonder about the reduction of the product range....rationalize...not the opposite....
..ironic no?
Only streamer.You're only writing about streamers or streaming amps, aren't you?
Only streamer.
Now a huge DAC market, which is replenished non-stop. Many people are experimenting by buying certain DACs, I am sure that each of the forum participants has at least one, and many have several of them. That's why I want to have a purely digital streamer in the lineup with reaching controls. Presets on the body!
I don’t think they need to reinvent wheels just add additional connections on pro plus like what Steve said and the device will go on production fast instead of starting from scratch. Sub out and xlr to name a few and you have pro plus V2.
I don't agree with you! That bunch of active speakers you're talking about often have a very mediocre DAC. Therefore, you have to use an analog connection!I would like to see a pure streamer without an analogue part, but with a good touch screen from a smartphone, not necessarily high resolution about 7", on which it would be convenient to control playback and presets, so that there would be no need to reach for a smartphone. Or with a simple matrix a screen that will display the name of a song or radio station large and on the body so that you can quickly select 10 presets. Perhaps it should look like a small 7"-8" tablet with an aluminum body with an adjustable angle, something like a Yoga Tablet. a tablet but with a streamer inside and that’s it. Wi:Fi, Ethernet for connecting to the network and an optical output and that’s it. Now there are a lot of active acoustics with digital inputs; they only need a digital streamer, there is no point in spending money on the analog part and analog connectors.
So when people say the Pro is great but the DAC isn’t good enough, we get the Pro Plus. When people say the Amp is great, but the amplification stage needs PFFB, we get the Amp Pro.
People say they like the Ultra, but would have like balanced outs…
What a great model to follow though, listen to what customers are saying they want and then provide it.
Depending on price I'd like to see a more powerful Amp Pro with c120w .... think that'd appeal to a lot of buyers.
Don’t many TVs etc have a feature to enhance dialogue that would suffice for many people without the addition of a centre speaker?I also think a 3.1 system would be good with a centre, main left / right and sub out which nobody seems to produce, I think the fad of surround / rear speakers has gone for a lot of people but it's still nice to have a centre for dialogue.
Subtitles?I think there was talk at the Munich Show by WiiM reps of a possible “ultra” version of the Amp with a screen - that might also present an opportunity for a more powerful version of the Amp as was talked about for the Custom Installation market a while back.
If you have a good stereo pair, and sit with yourself and speakers in an equilateral triangle, or your seat further away than that (but no closer), a centre speaker isn’t necessary, as long as you’re sat dead centre. Indeed, this is probably better, and certainly cheaper.
