Which cheapest Wiim to stream Tidal and spotify to dac?
Promso
Active Member
Hi Folks!
Which cheapest Wiim streamer would be still not loosing quality to stream Tidal and Spotify to Rme Adi-2 Dac Fs and headphone system?
I understand that even with Mini I can make such connection via optical, but it will have up to 48kH/16bit? Tho ChatGPT saying that i probably still can change these settings in the app? Is it true, won’t it be very laggy or something? Or I should better look for some more expensive streamer?
I'd only suggest going above the mini if you need a) a better dac (which you don't seem to), b) more inputs/outputs (which you don't seem to), c) subwoofer out, or d) the touch screen on the ultra.
Or support for Google Cast or independent RoomFit and EQ profiles.
The latter, probably not as a pure streamer, the former, OP need to know for themselves.
My headphone system is also in my office and connected to an integrated amp and passive speakers; so very similar use case to you. I also used to have an ultra and honestly, the sound quality and functionality in this set-up with the mini is just as good. I'd only suggest going above the mini if you need a) a better dac (which you don't seem to), b) more inputs/outputs (which you don't seem to), c) subwoofer out, or d) the touch screen on the ultra.
Or Squeezelite so you can run Lyrion Music Server.
