Why no more Audio Pro?
Audio Pro will have a new app as well. The question is will each companies devices be compatible with both apps.
They do ("Audio Pro W"), and while it can see WiiM devices on the network, it can't connect to them. A response from their support is unclear as to whether that will change. Guess we should return to this maybe a month down the line when things might be clearer - or not...
Please see Ryan's explanation of the situation.
Maybe i can say something about how software is even important as hardware.
Even more when we are taking about dac,amps..
You can say its even more important to develop this software or the support you are getting.
For instance i have a good usb dac and a good wireless headphone from a very known audiophile brand as Dali .
They sound good really and the usb dac has also bluetooth..
But they never really developed the software very much..
Other than some Chinese brands( soundcore for instance)who also deliver good headphones en they did deliver in the newest Bluetooth version and gave lots of possibilities in the app .
Dali never gave me anything on this manner they have no app .
Maybe the Bluetooth is also a hardware thing i dont know..but could,nt they do more on the software side of things.?
What do you think? Am i wrong about this? Or is the experience with this not yours?
I mean why should,nt i use it for listening to tv too other them only via te smartphone.
Maybe you can say the same thing with audiopro cant they see software is even important as hardware?
What do you think? Am i wrong about this? Or is the experience with this not yours!
I mean..the same thing with audiopro cant they see software is even important as hardware?
Audio Pro seem to be using WiiM software for the new speakers. Neither company is allowing cross compatibility.
Audio Pro originally included room equalization in their software description but has since dropped that from their description of the app. That raises the question as to how many of the Wiim software features will be available in the Audio Pro Mulitroom software - both now and going forward. Ryan's comment also indicated they were separate apps. Audio Pro still says they will have more frequent updates which seems to imply they will get at least some of the new features of the Wiim app.
I think we are going to have to wait to see how the software plays out over time. The relationship between LInkplay/Wiim and Audio Pro still seems somewhat uncertain at this point.
So Audio Pro clearly expected to have room correction but something has prevented it. Was room correction available as a menu item in the early release versions of the iOS Audio Pro app?
I wonder if Audio Pro will also remove Squeezelite...
I think its presence in the Wiim app is primarily dependant on the device firmware. The “legacy” audio pro app didn’t have such an entry as their device firmware didn’t support it, and even when it could pick up WiiM devices, it didn’t show such WiiM features as their app wasn’t looking for it. The new audio pro app can’t connect to WiiM devices at all (although it sees them) and I don’t have any w gen audio pro speakers to check (I suspect nobody has gen w speakers yet).
Not seeing it on their site now :(
funny. most of the glasbowl questions are linked to companies with a. 😂
I am not sure if the site ever mentioned Squeezelite but someone asked them about it.
Is there any word on this yet? I recently bought a Wiim Ultra + Vibelink Amp which are set up in one room, and I’m looking for a multiroom solution to integrate with it (to get away from Sonos) but I’m worried they won’t work well/at all if I buy Audio Pro speakers and run it through the Wiim products and app.
Other option is Bluesound and switching the Wiim stuff for a BluOs enabled amp and streamer, but that’s looking expensive…
I guess my question is, will there be more Audio Pro Wiim Edition speakers, which I’d be better off waiting for, or will the older gen Audio Pro speakers that have this symbol work fine?
I think it is a bit of a mystery currently.
I would wait until the Audio Pro W are actually available to be sure what is supported. With the new Wiim speakers being announced, my guess is that no more Audio Pro Wiim Edition speakers
Thanks. New Wiim speakers? Are you referring to the Wiim Sound only or are there more that are coming?
Also, does anyone have the older Audio Pro models running with Wiim and have any feedback on how reliable it is? I’m not fussed about extra features just want reliable multiroom
Yes, I meant the Wiim Sound and Sub Pro. They also announced at a show that there were working on a sound bar, but no details. It is unknown if they will fill out the line like the Audio Pro has done with the W line.
