juergen1601
- Dec 13, 2024
Have 3 echo dots and the Wiim Amp in one Alexa group.
When starting playing music with an Alexa command everything is playing in sync without problems.
After a while the Wiim Amp runs out of sync, Echo devices together are staying syncronized.
The time delay between the Echos and the Wiim amp Pro increases by time, after aprox. 30 minutes of playing, the problem is noticeable, and 30 minites later not acceptable anymore. It helps to finish playing and starting again.
The Echos and Wiim Amp Pro is in the same Wifi network.
Did a test: When using an Echo instead of the WiimAmp Pro at the same place, the problem is not there.
What can I do? Is there a problem with the Wiim Amp Pro or what do I do wrong?
Thank you
Thank you
