WiiM AMP Ultra + Pono(rega RP1) makes very LOW outputs
mipsan
Hello,
rega RP1's out to WiiM AMP Ultra's line-in.
RP1 uses MM cartridge, then connected directly.
No doubt simple.
But this connecting makes very low outputs.
I've no idea what's wrong and where to dig.
RP1 + MM Pono AMP runs pretty well.
Here, I use exactly same speaker systems for two combination.
Any advice and help will be appreciated.
Thanks,
mipsan
Even more entry level turntables up to 1k € and some a bit more expensive devices like the Revox Studiomaster T700 have onboard pre-amps. It can have a few advantages.
