Hey! Is it possible to connect an external DAC with WiiM Amp Ultra. Does it make any sense? I'm asking because I'm tempted to try DAC R2R from FiiO - K11 or K13. I wonder if there is any option to combine this? Or is it necessary to switch to WiiM Ultra and a separate amp, e.g. Vibelink?
Fyi, I just did this and can confirm it is possible. As others have stated, you will minimally need another amp/receiver to take input from the dac. I did this to also see if there was a noticeable difference between the Fiio K13 R2R dac and the Wiim Amp Ultras. I had a Denon 4308ci I snagged for $50 when I got a bundled with a 400 cd changer. It is key that your receiver/amp has a 'direct' or 'pure direct' input and mode or you'll just reprocess the K13 with the other amps internal dac. In my case there was an external in rca pair that bypasses ADC/DAC and selected pure direct. Keep in mind that many cheaper and older amps may not have this or it doesn't fully bypass. Really look into this for your target receiver/amp or getting the K13 external dacs flavor untouched won't happen.
Here is my connection matrix:
WAU acts as input hub for phono line in to rca in, cd changer to optical in, streaming via wifi to spotify connect lossless
I have an A/B amp or speaker switch by Douk with VU meters to change from amp A-WAU, to amp B- Denon. I like the visual appeal and the ability to go back and forth to compare the WAU vs. K13 dac.
DAC connection - WAU USB out to K13 R2R USB In. In this way, all sources on the WAU can flow out the usb preprocessing, except maybe the phono in which is analog. That may show some new flavor direct into the K13 by manually swapping from WAU.
K13 Routing
Ensure the K13 rca out goes to amp B rca in that is able to bypass amp B preamp and internal dac. Sometimes this is a special input and/or you have to enable direct/pure direct to avoid processing the external dac output. You must check for your specific receiver/amp.
Change WAU Audio Output to usb out
Changing Source on WAU - Simply change the WAU's Audio input to either wifi, optical or line input
Ensure the K13 input is set to usb in
Sample what the K13 R2R can do...
WAU Routing
Since all of your sources are connected directly to the WAU, it is acting as a hub to them already. Just change Audio Output to 'Speakers' instead of usb
Speaker A/B Switch
This is where the a/b soeaker switch comes into play. Assuming you do want one set of speakers and to toggle between WAU direct and Amp B and external DAC, you'll need a switch or you'll need to manually swap speaker cables from WAU to amp b. You simply take the L/R speaker out from each amp and route to Amp A, Amp B on the switch, then speakers out to the front /L/R.
What about a Subwoofer???
I was concerned I'd lose sub capability. I do have WAU sub out to a powered sub. When I use WAU native to speakers, works normally. When I change to WAU USB Out to K13 R2R DAC, I setup Amp B to think it has a sub and a crossover frequency same 80hz as WAU setting. So the DACs rca into Amp B only sends above 80hz to L/R speakers in 'direct' mode which limits pre processing but allows bass management. A trade off. If you set pure direct on amp B, you will send full frequency signal to L/R, no sub out but signal is untouched from the DAC. Meanwhile, the WAU is still sending from its sub out to the LFE on the subwoofer aligned to the 80hz crossover frequency.
Why the hell did I do this?
I like to tinker as a budget audiophile. This setup allows me to do A/B comparative listening. Try an external DAC, but still enjoy the all in one aspect to the WAU. No cable swapping needed.
Not sure if this was what you're looking for,but it covers a lot of your questions I think. Hope this helps you and others.
Bonus:
Fiio K13 R2R DAC w/Denon 4308ci in Direct mode via Ext In(bypasses internal dac and processing, I think)...sound evaluation 1 day in...My feeling is it has a fuller soundstage and has a warmer feeling to it. More dimensional while remaining clear, not veiled. Greater fullness at lower listening levels. Not earth shaking differences but noticeable and more pleasing to me. This will take more time and A/B testing. All that considered, the WAU as all in one using internal DAC and amp is no slouch. I love it's clarity and simplicity. The amplifier nicely drives my 4ohm KEF Q1 meta bookshelf speakers, which need a beefy amp. I also love these KEFs. I got a deal on an older 10" sub by James from 2004. In my condo setting, the WAU, KEFs and sub all pair really well. Good luck!
