I am wondering if I can use the wiim pro as input concentrator. Let me clarify a bit.
Current setup is the following:
- wiim pro as streamer (Spotify, Amazon and flac from a dlna server)
- Topping e30 mk2 dac
- Smsl a300 amp
Smsl Does not have native Trigger so i bought a iec plug Trigger to be driven On/off using wiim pro Trigger.
E30 has a native Trigger by sensing input level.
My intention is to expand input setup adding a cd player.
Cd player would be used only as transport, so my idea is to connect cd digital output to wiim pro digital input and then leave the chain as is (optical link between wiim and e30) in order to Keep Trigger function possible.
Does anyone use wiim pro as input concentrator?
Thanks
- Smsl a300 amp
Thanks
