Finally changed op amp too.
With OPA1611 lower frequencies gave wow effectSo much better bass extension and articulation.
"shhh" from vocals feels slightly less annoying. Satisfied more with this mod, very nice soundstage.
Thanks for advice on this forum![]()
Very neat work
What version is the PCB? V04 or greater? Have you changed the capacitors? With what type? Thank you
Is same, change only the packaging.Hi, I found 2versions OPA1611AID and OPA1611AIDR, what to choose?
Ciao YTL,I used nichicon fw for capacitors, and finally decided on philips 118. For those who are incapable of using it, it is recommended to replace the original power supply first and buy a good power supply. For the op ic, I chose opa627bp.
Is better the nichicon or Philips?The pcb is v04, the trial capacitor is nichicon fw and philips 118, the above are all 4700uf16v.
Thanks for your feedback... The my PCB is V03The above two sounds are very good, remember to listen for more than 40 hours, the sound will gradually improve.
