Going to need more info I reckon...
How are you using the plus? Digital or analog out? If analog, what output voltage is set?
Into what amp / speakers? Maybe you just need a beefier amp?
Or are you thinking more of a 'loudness' button to boost some frequencies (normally bass) easily?
I looked up the M41, and if I was looking at the right thing is it possible it's just not "big" enough for what you're wanting?
Or does something else playing through the D41 sound loud enough, just not the wiim?
i.e. have you played something else through the same analog in on the M41 that's louder / what you are expecting from the wiim?
Assuming you don't have a volume limit set and do have max / fixed volume set I'm really not sure what more you could do in the wiim app other than boost all frequencies via eq.
It would be very helpful if @Angelos58 could explain his problem more detailed.
To boost volume please use the volume control of the amp until your neighbours knocking on door.
