CrimsonSword
- Oct 10, 2025
My setup:
Query 1:
I’d like to know if with what I’ve setup with the inputs and outputs available – if I’m getting the best out of the first 4 use cases listed below (mainly first 2)
Basically I’m running everything from the WiiM Pro Plus to the Klipsch The Fives from the WiiM Pro Plus’ optical output to Klipsch The Fives optical input.
The Klipsch The Fives has the following inputs:
I think at one point got lazy and just used one input on the Klipsch The Fives, perhaps due to reliability on auto switching.
Query 2:
Essentially: Back to wired headphones route for vinyl.
WiiM Ultra 2 integrated into this setup (losing AirPlay - or running AirPlay off the WiiM Pro Plus to the WiiM Ultra keeping AirPlay in the game).
Wondered how people faired with WiiM Ultra and wired headphones and vinyl?
Or if in all honesty it wont be that life changing for me?
Other interest in WiiM Ultra is the display and the volume dial.
About the room:
Kept as visible wire free as possible.
Speakers, LP player, and WiiM in a unit in corner of room. Don’t want lots of wires to this area basically (hence use of AirPlay from AppleTV)
Room Correction with WiiM Pro Plus using the DAYTONAUDIO iMM-6C has been a revelation. So I want to run everything I can via the WiiM Pro Plus when using the Klipsch The Fives, as the placement of those without room correction was quite bass heavy and imbalanced.
About me:
Former tech obsessed but over years have simplified things, from – hi-res flac files on random drives, headphone amps and Beyerdynamic headphones to just wanting a setup family and guests can use. Working hours + family life and limited time = I’ve gone for quick enjoy music/movies with fleeting time to me obsessing on settings and setup before enjoying media and running out of time.
Use cases:
1) Spotify (Lossless) to WiiM Pro Plus (Query 1)
Connections:
WiiM Pro Plus: Optical out > Optical In: Klipsch The Fives
2) Vinyl on speakers (Query 1)
Connections:
Sony PS-LX310BT: Phono cable > Phono in: WiiM Pro Plus: Optical Out > Optical In: Klipsch The Fives
3) Projector with Apple TV 4K (Query 1)
Connections:
Apple TV 4K: AirPlay audio > AirPlay: WiiM Pro Plus: Optical out > Optical In: Klipsch The Fives
This may get replaced with me moving a Sony Ht-9 to this room and running the Apple TV 4K through that instead of AirPlay to the Klipsch the Fives
4) AirPlay (Query 1)
Occasionally guests/family visiting who use Apple Music instead of Spotify or I dabble in a Apple Music trial but thats less likely to happen as family locked into Spotify (which I’m ok with now Spotify finally has lossless)
Connections:
Apple device: AirPlay audio > AirPlay: WiiM Pro Plus: Optical out > Optical In: Klipsch The Fives
5) Vinyl on Headphones (Query 2)
Sony PS-LX310BT: Phono cable > Phono in: WiiM Pro Plus: Bluetooth Out > Bluetooth: AirPods Pro 3
Dire I know to play vinyl via Bluetooth headphones but it’s nice and easy with the WiiM Pro Plus. BT from the Sony with the AirPods Pro 3 kept being a faff to turn on.
- LP Player: Sony PS-LX310BT
- WiiM device: WiiM Pro Plus
- Speakers: Klipsch The Fives
- Headphones: AirPods Pro 3
- Projector driven by: Apple TV 4K
- Calibration mic: DAYTONAUDIO iMM-6C (USB-C)
Query 1:
- HDMI-ARC with CEC
- Bluetooth
- Phono/Line analog (with switch and ground screw terminal)
- Optical digital
- 3.5mm analog mini jack (n/a)
- USB digital (n/a)
Query 2:
About the room:
About me:
Use cases:
Connections:
Connections:
Connections:
Connections:
