Hello,
Since yesterday I have a problem with my Wiim pro plus. I can't connect to the wifi network in any way. I have tried all the options I could find on the internet.
The other smart home devices work without problems. I even tried using an old access point and could not connect either.
Resetting the device to factory settings(holding the button for 10seconds) also did not solve the problem.
I tried for two hours today and managed to connect to the network only once - unfortunately, after about 2 minutes, the device in the app got the offline status and since then it has not been able to add it again.
Maybe someone had a similar problem and knows the solution to this problem. Maybe the device is broken?
