Hi all
So i bought a wiim pro. Liked it so much that i bought 2 more. The last two came with a remote. Which if i remember was the wiim pro plus. If it helps im in canada and bought from amazon.
As of this moment all 3 go via coaxial cable to a dac in each setup.
I want to try going straight from my wiim to an amp. I think one of the versions that i own has a better dac than the other.
My question is how do i find out which is which? They look the same to me? Is there a specific model number that correspnds to the wiim pro vs the wiim pro plus?
Thanks
Thanks
