WiiM Ultra Firmware v5.2.813259 - Apr 8, 2026
5.2.813259 (In Progress)
Release date:
Apr 8, 2026
Highlights:
  1. Sub & Main Speaker Sync: Automatically aligns subwoofer and main speakers for improved timing at the listening position.
  2. Per-Input Screen Control: Enable or disable the screen display for each input mode.
  3. Headphone EQ: Added independent EQ for headphone output optimization.
  4. Standby Source Mode: Automatically switch to a selected input when entering standby, enabling instant playback.
  5. Spotify Smart Play: Resume your latest listening session with a single tap.
  6. Surround Setup: Simplified setup with full backward compatibility. (requires upcoming app update).
Screen:
  1. Playback Screen: Added a vinyl-style playback screen for a more immersive experience.
  2. Localization: Added French language support.
Playback & Audio:
  1. Playback Latency: Reduced delay when starting playback.
  2. EQ: Improved responsiveness when adjusting and switching EQ settings.
  3. Line In: Fixed distortion during extended playback sessions.
  4. Bass Output: Fixed low bass levels for Apple TV (Dolby 5.1).
  5. Audio Sync: Improved sync accuracy at microsecond level for better group playback (requires upcoming app update).
Radio & Streaming Services:
  1. TIDAL Connect: Upgraded SDK to resolve unexpected playback interruptions.
  2. Soundtrack: Updated SDK for improved playback stability and performance.
  3. TuneIn: Fixed playback issues for certain stations and improved resume behavior after long pauses.
  4. Deezer: Fixed unexpected playback interruptions.
General Improvements:
  1. Wi-Fi: Improved network stability and enhanced compatibility with Wi-Fi 7 routers.
  2. HDMI ARC: Disabling automatic audio output now correctly keeps WiiM in standby and defaults to the TV speakers.
  3. HTTP Server: Improved concurrency and stability under high load.
  4. Audio Input: Fixed playback crash issues.
  5. Remote: Fixed occasional disconnection and unexpected max volume issues.
  6. Alarm: Fixed incorrect alarm and preset volume behavior.
  7. Roon: Fixed occasional crash issues.
  8. EQ: Enables EQ for Dolby 5.1 playback.
  9. Alarm: Fixes BBC and vTuner alarms defaulting to the chime.
  10. Spectrum Display: Improves dynamic visualization.
  11. Qobuz Connect: Fixed occasional playback stopping issues.
5.2.812048 (In Progress)
Release date:
Mar 27, 2026
Highlights:
Screen:
Playback & Audio:
Are any of these updates heading for the WiiM Amp? It hasn't had an update for more than three months.
I was going to ask the same question regarding the rest of the range...the all-in-ones or other streamers
Does this vinyl screen have the hands of a clock by any chance? 😇
It will probably be the one featured in this short video clip under the heading
Immersive Cover & Per-Input Now Playing​
I‘m afraid you might be right. Sad!
There’s a subwoofer setting that align both main and sub by delaying sub, wondering what this brings?
You can now measure latency at your listening position using the phone's mic or an external mic. 🙂
Has anyone tested,?is HDMI having the options and working as in beta?
I.e If Tv switched on, it won't throw audio towards Ultra unless Ultra has HDMI input selected.
@hgo58 knows what I am talking about 😀
Wasn't that already the case?
Or does that refer not only to timing but also to level matching?
Doesn't this refer to the change that the measurement is now done at the listening position via your phone/mic rather than using the internal mic in the WiiM itself?
Burnside is correct; the original algorithm used a microphone inside the streamer to attempt time alignment between the sub and speakers, which is, fundamentally, an absolutely, completely wrong and utterly broken manner in which to do this. The update corrects the algorithm to utilize a microphone at the main listening position for time alignment purposes instead.
-Ed
Silly question... Shouldn't the wifi network latency be considered as an added delay/timing factor to manage also?
And what if network latency changes?
The defined corrective value for the listening point is anyway written within the Ultra's DSP without further need to be checked?
