WiiM Ultra Firmware v5.2.738432 Update - Dec 12, 2025
5.2.738432 (In Progress)
Release date:
Dec 12, 2025
General Improvements:
  1. Wi-Fi: Stronger connection stability; improved compatibility with Wi-Fi 7 routers.
  2. Sync Audio: More accurate calculations at low volume.
  3. Audio Spectrum: Better timing alignment with playback.
Music Services:
  1. Qobuz: Stabilized progress bar; fixed shuffle dropouts, playback-mode mismatch, and missing artist/track metadata.
  2. Soundtrack: Updated SDK; fixed disconnects when renaming the device during playback.
  3. SoundCloud: Fixed playback stops, genre-preset failures, and unexpected logouts.
  4. Plex: Added remote streaming over WAN.
  5. Amazon Music: Fixed position reset after back-to-back seeks.
  6. USB Library: Fixed disappearing album art.
  7. NAS: Fixed missing metadata.
  8. TIDAL Connect: Fixed playback interruptions after ~1 hour.
Playback Enhancements:
  1. Local files: Automatically skips unplayable tracks to continue playback.
  2. Seeking: Fixed next-track failures when seeking in the last 5 seconds.
  3. Stability: Reduced intermittent dropouts via synchronization optimizations.
  4. Resumption: Music now returns to the foreground after alarms or timers.
  5. Queue: Fixed crashes related to queue management and multiroom group naming.
  6. Radio: Resolved failures for certain station formats.
Bug Fixes:
  1. USB Out: Fixed a power issue that blocked standby while using USB output.
  2. EQ: Fixed a rare exception that caused no sound.
Is it possible to get the update file from support so I can copy it to a flash drive and update the Ultra manually? (The network update isn’t working for me.)
Have they not stopped sending out the update? They have recently said they have identified a problem regarding plex which stops Plex working correctly.
Support has said they are working on a fix.
Can't see much point in sending out firmware that they know breaks something then send out a fix for it?
But what do I know? 😁
I believe the issue here is a regional network issue for the OP that's not allowing access to WiiM's servers so isn't a general issue as such
It’s unfortunate that you don’t see the point in this. The issue is that due to Roskomnadzor’s blocks, most Russian users are currently experiencing the same update problem. Installing a VPN on my router, or using the method I described above, may be able to resolve the situation.
Thanks, that makes more sense than Wiim sending out faulty firmware.
He only doesn't see the point of installing faulty firmware when a fixed version is being worked on. That's how I read it anyway.
