Wiim Ultra getting hot and power draw / stand-by
Esque
I have an Ultra for about a month now. Very feature packed and good value for money. However, Its getting hot. Also without a power button it seems to be running 24/7, even with auto standby engaged. Is this normal for the Ultra?
Have yet to measure the power draw, but it seems like the unit won't go into a real stand-by. As the heat coming from the unit seems to be 24/7.
Yes, that's normal. Between 5-6 watts on or off. You could use a smartplug as many members do if it's an issue.
How hot?
You could power cycle your ultra. Unplug the Ultra for a couple of mins and plug back in again and see if that makes a difference
That's quite allot for "stand-by" Tbh.
Done that, no difference.
I can't find my laser heat gun, but it's hot to the touch. Way more heat than I'd anticipated for on a streamer. for reference, it's getting as hot as a 10 year MacBook on full blast.
How hot?
WiiM used to say it was less than 2W but that info has been removed. The Amp is only 3W.
Without an actual temperature reading, we can't advise whether your Ultra is hotter than you would expect.
Mine is currently just over 30℃ after a couple of hours use, and that is barely warm to the touch.
