What precisely no longer works?Unfortunately, this setup stopped to work after recent firmware update.
Like the Sony x800?I use the WiiM Ultra to play CDs in a Bluray Player that supports DLNA.
it is Sony BDP-S6700.Like the Sony x800?
can't stream music in DLNA devices.What precisely no longer works?
Are more steps required other than just enabling the CD-Play plug in?LMS running on mini PC (WIN 10) - CD player connected to PC Usb.
LMS uses CD-play plugin.
Wiim plays via LMS.
Player is a HITACHI-LG
You do need a CD drive with USB connection but otherwise only the CD Player plugin in LMS.Are more steps required other than just enabling the CD-Play plug in?
Thanks for the reply. The reason I asked is under the Plug-In page, with CDPlayer, it says requires CDDA2WAV to be installed. That looked real confusing to me lolYou do need a CD drive with USB connection but otherwise only the CD Player plugin in LMS.
Lyrion (LMS) can do a lot of things and apart from its local library integration it also supports most online music services and virtually all Internet radio streams. The music services it doesn’t support are Apple and Amazon. No surprise as both are closed code with no APIs outside their ecosystems
I can’t remember how I installed it TBH but I don’t think it was difficult. These days I use a generic input into LMS that will play anything that I play on a particular HiFi system - Turntable, CD, Tuner etcThanks for the reply. The reason I asked is under the Plug-In page, with CDPlayer, it says requires CDDA2WAV to be installed. That looked real confusing to me lol
It’s functioning again with firmware version 5.2.703742.Unfortunately, this setup stopped to work after recent firmware update.
Hi,It’s functioning again with firmware version 5.2.703742.
You are right, it is a beta version. The bug fixing is even not implemented in the latest release build 20250110.Hi,
Was that firmware version pushed out to you for testing, or is that an official release? I'm running 5.2.703434 build 20250103
