Wiim Ultra Radio Paradise problem
Gerr
Hi all
I'm getting a problem with Radio Paradise and I'm wondering if anyone else is having or had this issue.
When playing RP ...only tried main and mellow streams .....it plays 5 songs then repeats those 5 songs. I'm logged in to RP ....tried wi-fi and hard wired network. If I reboot or go out of RP and back in streams fine until you realise it's repeating another 5 songs ....
If I use my RP app and cast to Wiim all's fine. It's was fine before latest update....I've logged a problem with Wiim via the app.
Wiim Ultra ...latest firmware and app.
Cheers
Gerr
I have been playing the Mellow Mix for the last few hours without any issues on my Ultra.
Hi
Thank you ....I might try a factory reset then ...
I've got a few room correction setups stored ...need to do a bit of research before the reset then.
Gerr
Hi
Gerr
Try just a power cycle first - turn the unit off, wait a minute and turn it back on. A router reboot might help too.
