Certainly I hear mine too.I get a small pop from the speakers,
In my opinion, this pop is identical to what I hear on Amp pro.
Thanks for clarification!Yes, of course I know.
I was talking about procedure for checking the operation against @obertransae's device issue. (I wrote badly and may have misled you.)
Hi Wiimer,To be precise, I believe that the trigger can't put Vibelink into sleep mode
If I press the power button on the Ultra's remote, Vibelink's LED will dim and it will enter standby mode. (The LED does not turn off.)
I’ll check with our team on this—it’s designed to put the Vibelink into standby mode automatically. After a period of inactivity, it'll enter sleep then. I’ll keep you updated as soon as I have more information.
This is what it's doing, so all good.it’s designed to put the Vibelink into standby mode automatically. After a period of inactivity, it'll enter sleep then
Hi Mr Ee, Wiimer, TeamThis is what it's doing, so all good.
I think the confusion / clarification came from your post saying
'When using the 12V trigger input, the Vibelink can automatically enter and exit sleep mode'
implying that the trigger going off puts the vibelink directly into sleep mode, rather than into standby mode.
No. I describe it as a set it and forget it power amp. Choose your input, start with the vibelink volume down low, play some music, set your pre-amp/streamer volume to 100%, slowly increase the volume on the vibelink to the loudest you’d ever want your system to play then turn the pre-amp volume down to your usual listening level. After that, don’t touch the vibelink and just control volume via the connected pre-amp/streamer.Does the Vibelink have a fixed output setting to use the volume control on the pre-amp instead?
Thanks. That’s disappointing since I plan to use one when I get it as power for height channels. I have amps for the front and other surrounds but am two channels short.No. I describe it as a set it and forget it power amp. Choose your input, start with the vibelink volume down low, play some music, set your pre-amp/streamer volume to 100%, slowly increase the volume on the vibelink to the loudest you’d ever want your system to play then turn the pre-amp volume down to your usual listening level. After that, don’t touch the vibelink and just control volume via the connected pre-amp/streamer.
Why is it an issue? It just means you can choose the gain.Thanks. That’s disappointing since I plan to use one when I get it as power for height channels. I have amps for the front and other surrounds but am two channels short.
Turning the volume pot all the way up is a well defined setting (no attenuation, maximum power output).Thanks. That’s disappointing since I plan to use one when I get it as power for height channels. I have amps for the front and other surrounds but am two channels short.
I have the trigger cable as well and when WiiM turns off (5 minutes time is my setup - not using the remote, just leave it go off by itself) I hear the click from the Vibelink that turns it off as well as when it turns on, but nothing coming from the speakers. It's just the switch in the Vibelink making a small sound, as other appliances I have does, including an active sub I use in my primary system at home.Indeed - ultra power "off" causes vibelink to go to standby, and 30 mins later it'll go to sleep.
And it seems that now that I have a trigger cable connected, when I put the ultra into standby (and the vibelink goes to standby) I get a small pop from the speakers, similar to what I reported before when using the wiim app to turn the vibelink "off"..
Yep, I get the relay click too, but this sound is from the speakers.I have the trigger cable as well and when WiiM turns off (5 minutes time is my setup - not using the remote, just leave it go off by itself) I hear the click from the Vibelink that turns it off as well as when it turns on, but nothing coming from the speakers. It's just the switch in the Vibelink making a small sound, as other appliances I have does, including an active sub I use in my primary system at home.
