WiimPro + Lyngdorf TDAI1120 Sound drift to the right side
KnockKnock
I have a strange issue. I connect Wiim Pro to my Lyngdorf TDAI 1120 amplifier with Coax digital. When I listen to this, the sound (i.e. female voices) is tilted slightly 1-2 dB to the right side. When I bypass RoomPerfect the problem is gone.
And no problem when using Optical digital or Analog connections. Only when using Coax and RoomPerfect turned on.
I have tried it all (I guess): loaned a brand new 1120 Amp, made new measurements, new microphone, new/different Coax 75 Ohms cable, used two other digital outputs from a HifaceTwo and from a AirportXpress (and then converted to digital coax). Both do not have this tilted sound to the right when in fully RoomPerfect mode. Only the Wiim does this. I have not another WiiM to test with, but do you think another Wiim would do exactly the same or...??? Best Kurt 😀
Do you have any ideas? I
