🎶 Tech Tuesday: Unlock the Power of Smart Presets 🎶
What Are Smart Presets?
Smart Presets are a powerful feature available on WiiM devices to create customized shortcuts for your favorite content. Each preset is specific to the device it's configured on, allowing you to tailor them for different rooms and setups. Whether it’s your go-to playlist, a specific streaming service, or even a curated radio station, Smart Presets save you time and make your listening experience seamless.
Who Can Benefit from Smart Presets?
  • On-the-Go Music Lovers: Start your day with a single tap to launch your morning playlist, adjust the volume, and enable shuffle for a lively mix.
  • Multi-Room Audio Enthusiasts: Create unique presets for each room in your house. You can set party tunes for the living room on presets and and calming melodies for the bedroom.
  • Audiophiles and Home Theater Buffs: Use presets to configure EQ settings, adjust output interfaces, and set your system for the ultimate listening experience.
  • Routine-Oriented Users: From wake-up routines to evening relaxation tracks, presets can fit right into your daily schedule.
Advanced Features to Explore: Smart Presets aren’t just about quick access. Check out some customization options to get your ideas flowing!
  • Enable repeat or shuffle modes for playlists.
  • Adjust the volume for each preset.
  • Configure audio output to match your setup (e.g., Line Out or Optical Out).
  • Customize EQ settings for the perfect sound.
  • Set playback duration to automatically stop after a specific time.
Clever Use Cases:
  • Sleep Timer: Set a preset with low volume, soothing tracks, and a duration to help you drift off to sleep.
  • Party Mode: Shuffle your party playlist and crank up the volume in seconds.
  • Dedicated Zones: Fine-tune your presets for specific spaces, like a home office or a family room.
  • Headphone mode: Set up a preset for headphones powered by a WiiM Ultra to play your favorite tunes or a testing playlist to impress your friends with custom sound options.
  • Share some of you own use cases below!
Check out our detailed guides to learn how to use Smart Presets for more tips and tricks and how to rearrange them with the Preset Move feature.
I have a Pro with the production firmware and it has smart presets. Pull up device settings, choose Presets, and there should be a three-dot menu on the far right of the screen.
