Tech Tuesday: Deep Dive into Room Correction
I have followed all the good advises I received on this forum, but my RC still looks weird to me and I really hope I can get some extra help here.
To recap, I'm now using a Dayton iMM-6C external mic with the calibration file, connected to my tablet or to my phone.
I've set B&K Target Curve, Freq 30.0 to 4000.0 Hz, Smoothing 1/6 Octave and measured with stereo, one or 3 swipes. Given that my room has bad audio peakes up to around 100Hz, I would expect everything below that range to be reduced. But below's what I get. I wander if I'm doing something wrong... any help?
If this is weird or not depends on what the evaluation measurement shows, if you try to correct beyond the capabilities of your speakers and what mic you are using.
The PEQ filters alone don't tell the whole story.
Could you be a bit less macchiavellian, please? There's nothing wrong with my speakers (Sonus Faber Lumina II) and the mic has always received very positive reviews on the forum
Show us a screenshot showing the measured response, target response and predicted response. Then we can see the whole picture.
Also just to compare try another measurement with no calibration file selected (you have selected the calibration file rather than just adding it haven't you?)
I was just trying to point you into the right direction, not criticising your perfect speakers. ;)
The Lumina II are small speakers, still, and trying to "correct" them down to 30 Hz may cause exactly the giant >10 dB EQ hump that you got, depending on your room and speaker placement.
I missed the part about the iMM-6C, otherwise I wouldn't have mentioned the mic.
Here's the measured/target/predicted response. I know my speakers are small but they go down to 55hz. I wonder if that's the issue, but event when I select 50-4000 the result doesn't change much. And, I was non trying to be offensive, apologies if I came out that way.
20dB down at 50Hz then. Are the speakers far from the back wall? You could try placing them much closer to the wall.
Actually I measured again: they are 45 cm from the wall, can't push them back more, due to my speaker cables.
So, do you have more advise on how to set a proper RC?
I have no idea why the response is so low at 50Hz
I use a subwoofer.
Can you show us the L/R RC results?
This response from Erin's review paints a different picture to your measurements.
Mmmmm... they are bi-wired but in the proper way, I think...
How do I check that, other then looking at cables colors?
You are getting the same roll off measuring left and right separately so they can't be out of phase. Does it sound like the bass is missing?
It never sounds like the bass is missing, it sounds like there's too much bass even after RC. The only way to get rid of too much boomy bass so far, has been using DSPeaker, but I'd really love to achieve a good result with Wiim RC and drop DSPeaker
When you measure with DSPeaker do you see the same roll off. I always associate DSPeaker with subwoofers. Do you have a subwoofer?
This almost looks as if the subwoofer setting is on, but no sub is connected.
The slope of the resulting effective acoustic high pass looks way too steep, even for a ported speaker. Between 20 Hz and 40 Hz it appears to be more than 40 dB per octave. This almost resembles the natural roll-off of a reflex box (24 dB/octave) plus an electrical 4th order high pass filter.
Edit:
This OTOH would not explain why there is rather too much perceived bass ...
