netguyinPA
- Aug 7, 2024
Just received and setup my Ultra this weekend. What a great device for just a little money!
The system the Ultra is connected to is very simple: ULTRA (Line out)>> Carver M400t >> Acoustech Pl-200 II >> Klipsch RP-600M.
I primarily use Amazon Music Unlimited for my source. I also listen to iHeartRadio for clean streams of local radio stations.
With Amazon music, I get inconsistent streams when using UHD tracks, sometimes 44.1kHz, sometimes 96, and rarely 192kHz. All UHD tracks are capable of 192kHz. I thought that perhaps there is a transport problem, as I am using wireless as my source. So I ran an ethernet cable, but the results were still inconsistent, and I saw no obvious difference. Is it possible that the rate is being set on Amazon's end when the data stream is started, based on load? I'm going to further test with some local files to take the internet connection out of the equation.
The other issue is much less important, but still puzzling. My local radio stations on iHeartRadio do not stream at all. I can stream from other devices on the same network (laptop, tablet, phone, Echo), but not from the Ultra. It acts like a digital rights (local filtering) issue on the Ultra, but that is not the case with these other devices using the same global IP address.
If I'm misunderstanding how this should work, please feel free to educate me!
