Cool thanks. I’ll figure it out hopefullySurely, someone using chromecast will tell you if there is some more setting for chromecast.
Forgive me I'll back to home at end of August...
Ahhh ok that makes sense. All my settings are correct. So that’s probably rightThere’s currently an issue with Chromecast and the Ultra which constrains it to 24/48 iirc.
Threads have been merged.You got this answer in your first thread a few days before![]()
Play test audio on wiim app and see if you can hear it. If your toslink with coax then report back.It’s weird I thought chromecast was supposed to do 24/96. But starts at cd quality no matter what. Audio quality settings are maxed out.
HmmmDamn. Yea your right. My bad
Just the Ultra in the wiim range, but other non-wiim streamers too that are using the castlite protocol.There’s currently an issue with Chromecast and the Ultra
As in another thread, the issue has already been mentioned in earlier comments in this thread - there's an issue with the Ultra's implementation of Chromecast/Castlite. It's nothing to do with Qobuz, app updates or the router. Please read the thread commentsIt sounds frustrating! Since the Wiim app streams in full resolution, it could be an issue with the Qobuz app's Chromecast integration. You might want to check if there's an app update or adjust the streaming settings in Qobuz. Also, try rebooting your router and Chromecast. If that doesn’t help, using the Wiim app might be the best workaround for now.
Correct!As in another thread, the issue has already been mentioned in earlier comments in this thread - there's an issue with the Ultra's implementation of Chromecast/Castlite. It's nothing to do with Qobuz, app updates or the router. Please read the thread comments![]()
Well, well I haven’t seen you posted in a while or maybe I miss your post. How you doing fellow rock star?Correct!
