We're excited to give you this closer look at what makes the WiiM Sound tick. This exploded view shows all the components that come together to create our first smart speaker and we think you're going to love what's inside.
What You're Looking At
After years of building award-winning streamers and amplifiers, we listened to our community asking for an easy edition to their WiiM home setups to bring high-resolution, multi-room smart audio in a convenient package. So we built WiiM Sound.This was designed specifically with flexibility in mind. You can use it to expand WiiM home setups to rooms without speaker setups existing already, to bring audio easily to any space, to expand a WiiM home theater setup to be 5.1 with wireless surrounds or center, and to make whole home setups, even in rooms not traditionally used as dedicated listening room.
At the core, you've got a 4" paper-cone woofer paired with dual 1" silk-dome tweeters to delivers tight, natural mid-bass, with smooth, extended highs and wide dispersion. The result? A coherent soundstage that's clear, refined, and never harsh. Further customizable with our RoomFit software and EQ or PEQ.
This breakdown shows how we've packed all that performance into a compact form factor that fits anywhere in your home—on a shelf, table, counter, stand, or even wall-mounted.
The WiiM Sound delivers 100W total output and covers a frequency range from 35 Hz all the way up to 20 kHz. That means you're getting real bass extension and crystal-clear highs, all from a speaker that measures just 5.7" x 5.7" x 7.5" and weighs 5.5 lbs. And if you're looking enforce the low end, you can pair the WiiM Sound with the WiiM Sub Pro wirelessly.
The internal design ensures you get room-filling audio no matter where you place it, and our RoomFit technology (previously called Room Correction) actively takes precise acoustic measurements of your space, crafting customized corrections specifically for your room.
Coming Soon
WiiM Sound will be available soon on Amazon and select retailers. It will be priced at $299 US, £299.00 UK, and €349.00 EU when it becomes available.Want all the details? Check out the full specs and info on our website.
We can't wait for you to hear it!
