Introducing WiiM Sound: Your Smart Speaker for High-Res, Room-Filling Audio
AD_4nXd9pdn5vmIdlsudC_j9YSDmAoxv_PDGzsGsQ_qRgTDTlpl8aks5RZDcXq_fs3ruWLl6DHuJNaslVKO07_oYYg306NlhTpiL7wMaNyTXNvwnz0xhGTN08De4Kv1JUDqgkInpT8RZ
📢A landmark moment for WiiM! WiiM Sound, our first WiiM designed smart speaker, is here! The WiiM Sound is crafted from the ground up to deliver exceptional audio fidelity, smart connectivity, and seamless integration with the WiiM ecosystem.
After years of delivering award-winning streamers and amplifiers, we listened to our community and built WiiM Sound to fill a major gap in high-resolution, multi-room smart audio. With 24-bit/192 kHz playback, built-in room correction, and advanced EQ customization, this speaker adapts to your space and sound preferences like never before.
AD_4nXdltF_exblU5Ku1jhxDkd8_GFsA4fIb_3PU7yLrZGs6vOwd6l4g09d5GYgrO1PW905wEInLGpRZ3RMD34RYXzQv_BXFMQm39_ExgLVHm5N0fLc_O6l2WXEpsJxAoegUdHdJN_Io1Q
Why WiiM Sound?
  • High-resolution wireless streaming: Enjoy music, podcasts, Smart Preset and radio in stunning 24-bit/192 kHz quality—no phone required.
  • Next-generation connectivity: Equipped with Wi-Fi 6E, Bluetooth 5.3, and 100 Mbps Ethernet for fast, reliable streaming.
  • Advanced sound customization: Tailor your sound with 24 preset EQ profiles and a 10-band graphic and parametric EQ for precise adjustments.
  • RoomFit: Previously Room Correction, actively takes precise acoustic measurements of your room, crafting customized corrections for your audio equipment.
  • Stereo pairing: Seamlessly pair two WiiM Sound speakers to create a left/right stereo setup and expand your soundstage.
  • Home theater integration: Functions as a surround or center channel speaker in a Dolby 5.1 setup for immersive home cinema experiences.
  • Universal casting support: Stream directly from your favorite music apps using Chromecast, Spotify Connect, TIDAL Connect, DLNA, or Alexa Cast.
Immersive, Smart, and Customizable Sound
Whether placed on a shelf, counter, or wall-mounted, WiiM Sound seamlessly blends into any space while filling it with room-filling audio.
✅ 100W power delivered through a 4” woofer and dual tweeters
✅ Automatic room correction for personalized acoustics
✅ Stereo pairing - connect two for a true left/right speaker setup
✅ Multi-room sync - stream across your home with WiiM, Google Cast, or Alexa multi-room
High-Resolution Streaming & Universal Casting
🎵 Stream from over 20 music services or your personal library via the WiiM Home App
🎶 Enjoy effortless playback with Chromecast, Alexa Cast, Spotify Connect, TIDAL Connect, DLNA
🎤 Control hands-free using Alexa, Google Assistant, and the WiiM Voice Remote (WiiM Voice Remote included).
Powerful Connectivity & Customization
🔌 Wi-Fi 6E, Bluetooth 5.3, 100 Mbps Ethernet, 3.5mm Aux input for versatile connectivity.
🎛 Advanced EQ tools, including our 10-band graphic & parametric EQ, 24 preset EQ profiles, and input-specific adjustments.
🖥 1.8” high-res touchscreen display for direct control, album art, presets, and wallpapers.
🎭 Home Theater ready, use WiiM Sound as a surround speakers in a Dolby 5.1 setup with a WiiM device that has an HDMI ARC input such as the WiiM Amp Ultra.
Always Improving with Continuous Updates
🔄 Regular firmware updates unlock new features, services, and audio enhancements
Tech Specs
Connectivity: Wi-Fi 6E | Bluetooth 5.3 (SBC, AAC, LD3) | Ethernet | 3.5mm Aux
Sound Performance: 35 Hz - 20 kHz, 100W total output
Streaming Platforms: Chromecast, Spotify Connect, TIDAL Connect, DLNA, LMS
Multi-Room Audio: WiiM | Google Cast | Alexa Multi-Room
Smart Preset & Alarm Clock for personalized listening.
Dimensions: 5.7” x 5.7” x 7.5” (146 x 146 x 193mm)
Weight: 5.5lbs (2.5 kg)
Pricing & Availability​
WiiM Sound launches in Q3 2025 on Amazon and select retailers. Stay tuned for pricing details, we'll announce them when the product becomes available. Full details at www.wiimhome.com. Update: WiiM Sound will be $299 US, £299.00 UK, and €349.00 EU when it becomes available.
I don't think anyone complain about the price. We were just wondering why there is this big (~30%) difference. The answer have been that most of it is due to the difference in tax calculations.
I don’t think it’s big compared to the historic price difference between other WiiM devices. If I had had to guess before they announced the actual price for the EU compared to the $299 USA figure, I would have said nearer €369 given my table above typically showing 70 of a difference between the numbers for most recent devices. Nor do I think it’s all down to taxes.
Are WiiM immune to the Trump tariffs?
Integration with Google means that mic can be used to 'ask' Google Assistant any question, or only the ones that affect the device?
I mean: can I say to the WiiM Device 'Ok Google, turn off the lights in the garden's as I say to the Google Home device, or not?
