No, USB CIs it a Lightning iPad?
I think this is a very good solution.Just tried to connect turntable with an available cable directly with one of my Era 100 via the Sonos adapter. Sound is really good and streamed sync to all my other Sonos speakers. Control of speakers (incl. stereo pair) with the old Sonos App (16.1) works easily.
So, if I manage to establish my music library on the NAS and to implement it in the Sonos App (and thus do not need to stream music from my Android Phone), this might be the easiest (and cost-efficient) approach unless the long cable might cause problems. In that case another Era 100 might also be an option.
It is very cStrange, nothing wrong here. We use our Samsung and Apple charges criss-cross and never noticed such behavior. Will start to look at![]()
Can you be specific about Sonos and libraries. Ignoring, for the moment, the screwed up app.I think this is a very good solution.
I would still also consider installing a UPnP/DLNA server on the NAS, e.g. Minimserver. It's very easy. The benefit is the browsing experience with your personal music library. It is really a game changer compared to the Sonos app. You can use that Hi-Fi Cast app, or any other DLNA app to access Minimserver.
Sonos has completely neglected personal libraries in favor of streaming services for ages. That may make sense as streaming of course is the big thing. But there are better ways, as demonstrated by WiiM, Cambridge Audio, Eversolo and the developers of those DLNA apps.
With SONOS I think it’s difficult to separate app and library. It’s a system. When you use a third-party app, like I do as well, you don’t use the SONOS system any longer. You basically turn the SONOS components into stand-alone, DLNA- or AirPlay-capable active speakers.It is very c
I’m using a third party app, and find it adequate.
Assuming we're talking about Sonos here, as long as the groups/pairs are defined in the Sonos app you can play to them as long as you target the master using BubbleUPnP/Hi-Fi Cast e.t.c.The DLNA apps that I use are not aware of the SONOS system, so they can't handle Multiroom setups.
I play to my Sonos system from JRiver using DLNA all the time. I just play to one device and Sonos keeps all the speakers in that group in sync. You might want to try some other DLNA apps.The DLNA apps that I use are not aware of the SONOS system, so they can't handle Multiroom setups. When I want to play stuff across more than one room I revert to AirPlay. Weird enough, that works faster with the SONOS Players on my network than if I group the Players from inside the SONOS controller app.
Works fine with LMS (LYRION).I play to my Sonos system from JRiver using DLNA all the time. I just play to one device and Sonos keeps all the speakers in that group in sync. You might want to try some other DLNA apps.
Unless you've got Play:1s (like I have) where there's a weird ~12 second delay at the beginning of playback.Works fine with LMS (LYRION).
No delay for me (ikea symfonisk Frame)Unless you've got Play:1s (like I have) where there's a weird ~12 second delay at the beginning of playback.
The only other speaker I've tried is the Era 100 which was fine, so it may just be a Play:1 or 1st generation incompatibility.No delay for me (ikea symfonisk Frame)
Yes, exactly, as long as a group is defined within a SONOS system it can be selected this way, the DLNA apps I've used however are not aware of SONOS groups/pairs or able to define them. At least mconnect, 8Player and JPLAY can't.Assuming we're talking about Sonos here, as long as the groups/pairs are defined in the Sonos app you can play to them as long as you target the master using BubbleUPnP/Hi-Fi Cast e.t.c.
I've been doing this with Play:1 for years.
Oddly enough, the new Sonos app has a lot in common with those other apps.Yes, exactly, as long as a group is defined within a SONOS system it can be selected this way, the DLNA apps I've used however are not aware of SONOS groups/pairs or able to define them. At least mconnect, 8Player and JPLAY can't.
So, at least for spontaneous grouping you have to revert to the SONOS app or use AirPlay (or whatever) like I do. Using AirPlay has the advantage of working across hardware brands. Adding a WiiM streamer to a group of SONOS players works just fine.
Your message read as though it wasn't possible to play to Sonos multiroom, so my comment was just for clarification really.Yes, exactly, as long as a group is defined within a SONOS system it can be selected this way, the DLNA apps I've used however are not aware of SONOS groups/pairs or able to define them. At least mconnect, 8Player and JPLAY can't.
I'm not a fan of the phone/tablet being part of the chain, especially the audio chain, so it would only be if I wanted Sonos and WiiM to be in sync that I'd resort to AirPlay, if I had a device that could.So, at least for spontaneous grouping you have to revert to the SONOS app or use AirPlay (or whatever) like I do. Using AirPlay has the advantage of working across hardware brands. Adding a WiiM streamer to a group of SONOS players works just fine.
Usually, when I group SONOS speakers with my AVR or a streamer, using AirPlay, it's not exactly a listening session, background music more like. For that it's great. I never sit down to listen to music using Airplay, though. For audio quality it's mostly NAS with Minimserver into a streamer via DLNA.Your message read as though it wasn't possible to play to Sonos multiroom, so my comment was just for clarification really.
Whilst BubbleUPnP doesn't identify the slave/master it does allow you to hide servers and renderers so it's easy to pick the right one. My dad has an inherited iPad so for him - who has considerably more Sonos speakers than I do - I name them '<Room> Master' in the Sonos app so it's less confusing when playing from Lumin (UPnP).
I think I read somewhere that Roon can define Sonos groups, but as far as I know that's the only third party thathas given them enough money to be able to do socan.
Great choice by the wayFor audio quality it's mostly NAS with Minimserver into a streamer via DLNA.
