Ongoing Beta Beta Test: Replay Gain for TIDAL
I think I see what you mean now. Are your R128 tags actually named R128?. I just have REPLAYGAIN tags generated using the R128 algorithm.
A little more explanation.
Yes. What you have is pretty common. R128 tag values are just written to the old Replay Gain tags. I have 2 sets of tags - on labeled as ReplayGain and one as ReplayGain128.
The other issue is what reference level they are using. The R128 standard uses -23 LUFS but some people find that too quiet, so some programs use a -18 LUFS reference for R128. -18 matches the old Replay Gain volume better. I am not a Roon user but as I understand it Roon has a specific tag for the reference level for each track. Other programs provide other options to increase the gain while maintaining the dynamic range differences.
This has been a much-discussed topic for other players and in the past it has been hard to figure out what techniques players are using. The main reason it is important is that the old Replay Gain had a higher reference gain, so strict R128 gain is often too low for many people.
So, I guess the full question is
1) What tags are being used? In the Tidal case, whatever Tidal uses. For other sources this become relevant.
2) Does it assume the tag value is R128? I presume so.
3) What Reference Level is being used? I presume -23 LUFS.
Also, at least in the past as I understand it Tidal only used Album Gain tags. Wiim says they are providing both Album and Track Gain, so how are they doing that? Has Tidal changed changed their tagging or it Wiim going something on their own? Some programs look at consecutive tracks and if they are from the same album treat those as an album and apply gain relative to one another. Roon actually has separate tags for Album and Track gains. LMS uses Smart Gain.
As I said, there are long discussions about these issues for other players and some players have provided unique implementations. I am just hoping Wiim can provide some details on their implementation.
Sorry for the long-winded explanation, but I have been through these issues before.
Yup I use -18 LUFS and even with that modern recordings have more than 10dB attenuation so I would never use -23 LUFS. There would be more complaints about the gain of the WiiM Amp if everyone used -23 LUFS 😃
Hi Wiim Pro Plus user, have you received further firmware update after this beta firmware was installed? I didn't receive it since that.
Thank you.
It’s official now on ultra. Newer product get updated first follow the older ones. It’s the nature of business everywhere.
I meant how to get the normal firmware update since the beta firmware was installed and no more latest come to my device since that.
Thank you.
Thank you.
Under device info if it say beta you can remove that and official firmware will be installed. If it doesn’t say beta send message via wiim app so they can remove it. Participating on beta will not update your device to official that’s why many don’t want to participate on beta especially if it’s not label beta which can be pain on the a** to remove.
It's still the previous update. How's yours?
