Dear WiiM Development Team,
your streamer is simply a fantastic tool.
There are a couple of things I would suggest though.
The first, which frustrates many people, is the fact that the audio from the digital output is bit perfect or no.
Now, for the peace of all users, I would like to ask please if you can put a single simple setting in the menu, called Bit Perfect, to be set On or Off. So that when active it creates a direct stream from the source to the digital output, bypassing any volume controls, eq, limiter, sample rate converter, etc.
So we don't have to check every time that everything is ok...
Thanks in advance for your attention.
