Bluetooth Stutter
Shozzer
Morning All,
Thanks for reading.
Steve
I had not—thanks for pointing out that I needed to reply to their email (I thought the email was just the standard acknowledgement that they had received my support request and that they would get back to me).
I just sent off the reply.
If you read carefully, that's what the mail actually says, but is usually overlooked because people assume otherwise.
And that's why I mention it from time to time. :)
