Bluetooth Stutter
Shozzer
Morning All,
Thanks for reading.
Steve
Sadly, this is generally my experience - I get stutter on all BT headphones linked to the WiiM Pro. There are times when I can get a run of 7-8 minutes with no issue playback and then all of a sudden the stuttering kicks in. Once it starts it won't stop. Pausing and waiting a few seconds can reset things but soon after the stuttering starts again.
Steve
Thank you for your suggestion,but any combination of these settings doesn't improve or even change a bit in my case.
If you have raised a ticket for this, please let me know and I’ll escalate it to WiiM. Again, good troubleshooting :)
Thank you.
A little time has passed, but I have submitted a ticket. 493048
Why does my butt itch when you compliment me? Is my tail trembling? 😁
By the way, the @Shozzer problem feels like an initial defect of the WiiM.
Also, I feel that the distortion that @onix heard is different from mine. He likened it to an FM radio, but what I heard was a noise that accompanies the high frequencies.
Also, based on the testimonials that there were no problems with older devices, there may be another cause. For example, it may only be a problem with devices with high-resolution codecs such as noise cancellation or LDAC. (I've heard similar distortion in LDAC before.)
Although extensive research may be required,
I hope the WiiM team can identify the cause. 😊
I think that the issue (as it affects me), is greater than high resolution codecs. It affects both low end and high end BT devices. The most stable is the Dali Katch which only stutters at the beginning of playback and after a pause it rights itself and plays flawlessly thereafter. Stopping and starting play can cause the issue to resurface.
I am also waiting on tickets raised for a response.
Steve
Thank you.
I anxiously wait for the problem resolution, I have the same problem with my Sony WH-1000MX4 but not with their IEM version
Sony WF-1000XM4​
Thank you very much for the good article! Only question left, why this interference does not happen with other devices except WiiM? I hope to recieve an answer from WiiM...
Are your other devices also connected to wi-fi when you connect to them via Bluetooth ?
Yes, counted at least three of them, one more really had enterference but it does not relate to music - it was bluetooth mouse.
