Bluetooth Stutter
Shozzer
Morning All,
Thanks for reading.
Steve
Update.
Im listening for days now on my amp to tv, Netflix ( HDMI arc).
Every night my BT headphones gets automatically connected when i power on the amp and Daliio6.
Super clean sound..in stead of the BT of the TV I always use the BT connection of the amp.
No issues whatsoever..
Powering on the TV, amp powers itself on and I can control the volume with the remote of the TV.
Very pleased.
It's even worse for me it seems after update. Instead of every 3 seconds it's every 1.5 second or so.
EDIT:
Turning off "MQA Beta" did help a little bit, but the distortion is still there.
EDIT2:
After device restart it once again stutters constantly. Unusable with my Technics A800...
EDIT:
EDIT2:
In that case, raise another ticket ASAP after it happens so WiiM can attempt to diagnose further
Submitted but even reporting is not working as it should as it replaced my ticket title with my personal email. Also it's impossible to reply to previous ticket due to the fact it requires chosing issue type which is non-editable field..
I was very pretty happy when my Pro upgraded to the latest FW and music played without stutter straight out of the gate. Then, a few minutes in there was a stutter and things recovered. After that it has gotten progressively worse and the stutter is back although I have not had the trilling. When I get time this evening I will try again and submit a report but I have to be honest and say that my patience is fast running out. I have turned the 2.4Ghz connection in my router back on as I was suffering with Wi-Fi connectivity issues around the house, and having it turned off didn't help resolve the BT issue with WiiM anyway. Whilst I understand that, in theory, interference can occur, I really find it hard to believe that new devices need 2.4 turned off to work properly, when older devices seem to cohabitate quite nicely together. I do appreciate advise given and really do want to see this working product. The WiiM concept is fantastic.
Steve
They did rollback of my WiiM to previous firmware somehow. Of course the issue is like it used to be - stuttering every 3-4 seconds for period of 1 second.
Apparently they have rolled back my FW as well. I will check it out when I get home but I think the updated FW experience was better than the previous - it was still not really usable as you have to keep pausing to cure the stuttering. I could certainly not showcase it to anyone else in its current state.
Steve
I have bad Bluetooth stutter with WiiM Mini and WiiM Pro via Sony WH-1000XM4 headphones. I’ve submitted a ticket too but have not yet had a response.
Hi Kpyhifi,
I apologize for any inconvenience. Could you please provide your ticket number? This will allow our team to follow up on your issue quickly. Thank you for your patience and understanding.
Morning All,
Thanks for reading.
Steve
Are you in an apartment building? Are you or neighbors using older WiFi (2.4 GHz)?
Bluetooth uses UHF radio waves in the ISM bands, from 2.402 GHz to 2.48 GHz. So, WiFi, microwaves and other emitters can interfere with Bluetooth since it's a very low power emitter intended to go up to 10 metres / 30 feet and anything with higher power will stomp on the Bluetooth signal.
Workaround for bad RF (radio frequency) is often to use wired connections which isn't always idea. Or you could move :)
