Indeed, but it'd be significantly cheaper.I doubt the Plus can even come close to the ADI-2 in terms of sound quality, and there's no way in terms of overall performance or features.
But what is the reason that you mentioned ADI-2 specifically?Indeed, but it'd be significantly cheaper.
Only contemplating an adi-2 as a room shuffle means I need (or so I've told the better half) another headphone / hifi streaming solution.
I have unused cans/amp/speakers lying around, but not a spare streamer / dac. It's only an extra 0 after all...
Maybe a Plus would suffice for the amp/speakers I intend to use, but I still want a headphone setup there too, so no other reason than to "justify" another bit of kit.But what is the reason that you mentioned ADI-2 specifically?
It’s also on the banner line (or chyron?I *was* 99.9% sure that the only reason I knew about the amazon event was from a wiim 'advert' stating it'd be discounted, 'cos I remember wondering whether to get another pro or to wait for a pro plus.
But now I can't find the post...
Well, if you need a new toy, you are not scared by RME technical approach, you think about headphones correction for your preferred target, you consider a simple room acoustic adaptation, you prefer a transparency of the sound and focus on the faithful reproduction instead of adding a joy if it's missing in the source material...Maybe a Plus would suffice for the amp/speakers I intend to use, but I still want a headphone setup there too, so no other reason than to "justify" another bit of kit.
Maybe because he heard that the Pro Plus will have the same DAC the ADI-2 v2 had, the AKM 4493SEQ?But what is the reason that you mentioned ADI-2 specifically?
Is this AKM chip confirmed for Plus?Maybe because he heard that the Pro Plus will have the same DAC the ADI-2 v2 had, the AKM 4493SEQ? I know the DAC chip alone doesn’t say it all, but maybe hanging off a few weeks till the end of the month till the Pro Plus is released in the USA might prove worth worthwhile…
Yeah, confirmed for the Plus.Is this AKM chip confirmed for Plus?
RME had switched to ESS and no longer uses AKM for ADI-2.
Looks like I didn't pay attention.Yeah, confirmed for the Plus.
I understood RME no longer used AKM, but wasn’t that largely down to the AKM factory fire? I think I read recently that the AKM chips are now being manufactured elsewhere until they get their production facilities fully back online.
I did suggest thatAKM 4493SEQ you say.... maybe I should have asked for a unit for testing, damn you.
I can imagine @VintageFlanker asked for it already![]()
HeheOne is on its way to him![]()
But you hid the most important information...I did suggest that![]()
It’s good (and maybe brave) of WiiM to ask him to review it given his warts and all review of the Pro - I’m sure he’ll do another thorough job. Let’s hope the Pro Plus addresses the shortcomings he found with the Pro.Hehe![]()
Well, I guess they know the improvement related to the much better chip, so they are not scared at all. Of course, if the entire analog path is on par.It’s good (and maybe brave) of WiiM to ask him to review it given his warts and all review of the Pro - I’m sure he’ll do another thorough job. Let’s hope the Pro Plus addresses the shortcomings he found with the Pro.
For the line out performance they quote (and you’ll understand it better than me):Well, I guess they know the improvement related to the much better chip, so they are not scared at all. Of course, if the entire analog path is on par.
Looks good but details matter as usually.For the line out performance they quote (and you’ll understand it better than me):
- SNR: 120 dB (A-wt)
- THD+N (1 kHz): 0.0004% (-108 dB) for 44.1k to 192k
- FR curve: +/- 0.1 dB
