HappyHighwayman
Active member
- May 11, 2023
It makes zero difference, I won't be able to hear it, but why would 192 lhz / 24 bit work for optical for me and only 16 bit 192 for coaxial digital? Is it a receiver limitation?
I have the Pro connected to my Topping D50s through COAX and i have 24/192, as confirmed by the DAC display. I have a 75 Ohm COAX cable.It makes zero difference, I won't be able to hear it, but why would 192 lhz / 24 bit work for optical for me and only 16 bit 192 for coaxial digital? Is it a receiver limitation?
Ok, let us forget the internal DAC of the Yamaha.
The digital work is done ONLY in the Topping (external) DAC.
So, the digital capability of the Yamaha is not the question. He gets an analog signal via RCA out of the Topping what he accepts always, and no further digital work will be done.
