Cover for Wiim Sound
fahzz
I plan on using this on a covered porch. I've used a regular TV out there for years without issue. But I'm wondering if anyone has found a suitable weather resistant cover for a WIIM Sound that I can put on it when not in use. Thanks.
How about this?
Sorry, that was a lame joke.
Searching for "waterproof speaker cover outdoor" on Amazon yields many results, but finding one that fits size might not be easy.
This one appears to be wall-mounted, but it seems usable as a stand-alone unit too.
This is slightly taller than the WiiM Sound, but I think it will fit perfectly if you place a base a few centimeters tall underneath the WSound.
A WiiM Amp on the inside, with weather resistant speakers on the porch, could be another option (wired appropriately of course).
