onelivewire
- Sep 6, 2023
One of my favorite WiiM capabilities is essentially the ability to replace the role of a preamplifier in an audio chain, and allowing me to remotely control different zones both as a group and independently.
One issue that I've encountered, though, is volume when adding a WiiM to a listening group. If the volume was cranked from playing a quiet song or use with a different input with a lower 'line-level', my speakers blare when first added to the group and I must rush to adjust them.
Similar to the Alarm function which allows you to set an explicit volume level, a default volume that is returned to after going into standby would be a great feature to be able to set on each device.
