Any of those components are obsolete as they either only work on the old 32bit version of foobar or are already included in the standard package.I notice there’s also a “UPnP/DLNA Renderer, Server, Control Point” component which would appear to make your foobar library visible as a upnp server to the WiiM home app - do you maybe have that instead?
Yes!Do you have the “UPnP MediaRenderer Output” component installed and can you see any other UPnP players on your network?
Sorry for the daft question, but is the Ultra on the same network and are you sure it‘s got a connection?I can see all my other devices, only wiim ultra missing
What about the settings from my earlier post?Yes, sorry before asking i have spent 2 days trying everything... I am posting because i ran out of ideas to try really...
Also the reason for foobar is because my sacd iso collection
Hmm, maybe try an update of foobar and check the settings for your WiiM in your router. Otherwise I currently out of ideas myself.Yes i can see exactly that
Have you checked basic connectivity?I can see all my other devices, only wiim ultra missing
Just opening the page is enough of a testThank you all for taking the time
I got above open but there are tons of things there... What should i check for?
