One of many, many advantages of wiim comparing to for example eversolo is DDC (Digital - Digital converter / pass) function. Wiim can work with external (much better) dac, and the same time it can use cd transport or other digital input as a source (eversolo can not). In case of transports, quality of sound is depended from transport clock. In cheap transport $20-type, may be lower. So question is, does wiim improve clock signal, by performing reclocking when using for example optical in and optical or coaxial out? Or source clock signal is still a factor?
I'm assuming that wiiim should fully eliminate any cheap source clock problems in case of usb out. So with wiim $20 transport sound quality should be the same as $2000 transport - as is in case of other, dedicated, typical ddc's. But is there improvement in case of spdif out?
