Dropouts on coaxial output with ARC input
Make ticket when you encountered this problem via Wiim app and send logs with that. Maybe they can do something. But currently Wiim sends digital data throught to speakers and not process it. If they will change that, then this will possible fix issue.
With HDMI to Wiim and line out to speakers not cause issue because Wiim own DAC process material.
Doesn't the Wiim Ultra have to process the TV's digital data it to apply EQ or Room Correction?
Nope. Based on support they passthrough this ti speakers. On this case Genelec.
Strange - I'm not sure I trust their Support on that, then. When I apply EQ using the Ultra, it definitely results in different audio from my Genelec speakers, which means that the Ultra must be doing more than just passing it through.... Thanks for your thoughts!
I'm also using Genelec speakers with the AES input, and also having the same issue with others on this thread.
I’d say yes too. I fear the question to support or the response may have been misunderstood. If fixed volume is used, with no EQ/PEQ etc, then yes the signal is passed thru unchanged but if you use any of those features, you are telling it to change the signal.
Edited for typos…
I’d say yes too. I fear the question to support or the response may have been misunderstood. If fixed volume is used, with no EQ/PEQ etc, the yes the signal is passed thru unchanged nut if you use any of those features, you are telling it to change the signal.
Makes sense! Thanks.
Hard to say. I asked is Wiim doing anything for digital signal which is connected in via HDMI.
On analog side all signals are manages Wiim and their DAC.
Has there been any new software updates? On last few months.
I submitted a support request for the drop-out issue and received the following:
We have identified the cause of the issue and will introduce a skew method in a future update to address and optimize the problem. We apologize for any inconvenience caused.
We appreciate your patience and understanding.
Best Regards,
WiiM Support
