Eq for Wiim Ultra connected to TV
Promso
Hi Guys,
Finally got Wiim Ultra and AE1 speakers. I’m very happy with this setup!
Only thing is not perfect is that I cannot hear speech on TV as good as on TV speakers. For music it is all perfect. But for TV I need to turn on volume higher than usual to understand what people are speaking in movies.
I did room calibration, for music it improved, but for tv it makes even slightly worse, so turned off eq for tv. And my wife agrees with me.
Maybe can recommend any special eq for tv? Or anything else? If I’m not mistaken, worse situation with women voice.
Tv connected via hdmi arc. It is Sony Bravia android tv KD-65XH9077.
Hi Promso,
You can now set different EQ settings for each input source, such as TV and streaming music, directly via the app. This saves you the hassle of adjusting EQ settings every time you switch sources. Give it a try and let us know your experience - we’d love to hear your feedback!
Hi Promso,
Yes, this is what i exactly did at once. Amazing and simple experience!😂 just for newbie in audio for me was difficult to understand at first that factory made presets are in Graphic EQ section, but saved room correction eq is in another section Parametric EQ. Maybe would be good idea to find them in any section.
It wouldn't make sense to put saved PEQ filters for room correction in the Graphic EQ section. You can access the saved room correction filters directly from the room correction page.
I meant other wise - factory made graphic eq filters to add to parametric eq selection. As a newbie i want to do room correction, which is something what is done without my know how. But i didn't realised that there is another section with pre-saved graphic eq settings when you jump at once in parametric eq after room correction is done. But anyway, maybe I'm digging here too deep, i just needed to improve my knowledge..
At the moment you can't use graphic EQ at the same time as PEQ anyway. If you try to use graphic EQ you will disable PEQ.
That would be great, at least that you at once would see that there are also option for graphic eq presets.
Here is the feature request that you should upvote using the orange arrow icon:
:D
