Automatically output audio to WiiM whenTV is on Set to OFF, no sound via hdmi arc when manually selected
nicolasd
Location
Argentina
This setting is set to off because I’m not always around when the tv is turned on by someone, and the audio system would be (usually) off. I use a pair of Adam Audio T8V active monitors with a Wiim Ultra, which is connected also to the TV via a hdmi arc cable… Everything used to work fine even after the latest update, I’m not sure what could have happened… But now when I do want to listen to the tv via the audio system, with everything on I switch the Wiim to hdmi, the tv shows hdmi output, all perfect on paper… except no sound comes out of the system.
