Firmware 4.8.528755 build date 20230908 PEQ
Mr Ee
Community Curator
Location
Sydney, Oz
One of my Pros updated to this fw version.
Simply cannot get PEQ to work.
Very buggy.
No matter which number in the 3 cols I press, it always says "Change the Q factor:"
The numbers shown on the page do not update when I enter new values, but it does seem to be remembering them as the changed values are shown in the popup when I re-press them.
There is no slider, just a number input screen.
The cursor always starts on the left, but the 'keyboard' shown doesn't have arrows to move the cursor, so you always have to press in the number to be able to delete/enter something. Particularly silly as the only delete key is to delete the character to the left of the cursor.
Where is the graph of the curve?
Although it does seem to be remembering each number I enter for each cell (row / column), if I exit the eq screen then go back into it, the last change i made to any value per row, such as setting gain to 10, is then applied to the Q value for that row.
Possible. My android phone is old, based on 9.0.
This is likely the issue then.
My tablet is even older than your phone...
Good job I was likely to just leave (p)eq off anyway, but I thought it might be fun to have a play.
If I want to adjust the bass then I'll just have to drag the speakers themselves ;)
