High quality radio
gazza1101
Senior Member
I would like to be able to get good quality radio stations, as far as I can see the radio options we have are low quality bandwidth.
Upvote 0
You can play whatever high quality bandwidth streams you can find through Open Network Stream. Isn't that enough?
How would you define good quality/high bandwidth? When it comes to Internet radio many stations don't even produce a stream better than 128 kbps MP3. Nothing WiiM could do about that. Radio Paradise when selected as a music service e.g. is lossless FLAC.
The station search on vTuner explicitly lists the available bitrate and compression algorithm.
Vtuner replies with internal server error 500
Radio paradise in the WIiM home app is lossless flac quality
Other than Radio Paradise what other stations are available via WiiM in high res audio? I just tried to access my usual stations (Radio 4, 6, London) via Vtuner, and that appears to not be working. So I’ll stick to listening to them now via the BBC Radio option on WiiM Home (but I’m unclear as to what the quality of these streams are, as it’s not published). 🙏
See various suggestions in this thread. Use the Open Network Stream to add the url to WiiM
INCREDIBLE 🙏🙏🙏 Thank you so much. This has opened up a whole new world of hi res internet radio to me. Amazing 🤩
https://www.radio-browser.info/ shows every stream´s URL so adding a stream URL manually can be done currently in a Wiim.
Hopefully adding radio channels more easily from radio-browser will be supported in Wiims in the future though.
Like this, examples from HifiberryOS64 search, first search with the search term "yle" and another search with the search term "flac".
Just press the star sign and the webradio channel gets added to your favourites.
Very handy.
Awesome! More favourite hi res music stations recommendations please 🙏 Radio Paradise and my usual BBC stations are fine. But I’d like to check out a few more that folk really recommend now. Just listened to Mother Earth Jazz, which is immediately now on one of my 12 presets.
Probably mentioned in the link I posted but worth repeating
Yes, got that. And that’s a very useful but very LONG comprehensive list of ALL hi res stations. I’m just after 3/4/5 other personal recommendations that folk recommend and listen to regularly by habit, if possible 🙏
Like this, examples from HifiberryOS64 search, search term "yle" followed by "flac".
Just press the start sign and the webradio channel gets added to your favourites.
Very handy.
Does YLE have FLAC streams? I couldn't get the search to work on the Radio-browser page.
