Well, let’s just say this is rather academicalI am afraid I don’t understand what you are saying…
Can you please explain it to an eight years old child?
What affect more of the sound jitter or sinad? Sorry for a silly question.Well, let’s just say this is rather academicaland was more or less addressed to OP. But take a look at the first pics in the thread 'My Ultra tests' . The digital output signal graphs (measured with a scope) look much more accurate for Ultra, but once you measure actual jitter spectrum of the analog signal reproduced by this specific DAC there seems to be no visible improvement compared to Pro.
If talking just about numbers - no, it does not outperform current top end DACs. It never did.You have rme dac right? Is the dac you have has better measurements than any current line offer by topping/smsl? From what other reviewer saying despite its outdated chipset it outperforms the top end topping/smsl?
One remark, this eye pattern was made for highest bandwidth 192 kHz test signal. Tests above are for 48 kHz. test signal.Another interesting observation is that a significantly more accurate SPDIF eye pattern with Ultra vs Pro does not translate into a significantly better jitter spectrum in this setup
He’s understanding in audio is top notch. We learn many things from him.Fantastic work, as ever. Thank you very much for your invaluable contributions to this forum @onlyoneme
Really nice words, thank you, but far from the reality. There is a lot of things in audio which are unknown for me and my knowledge has huge limitations.He’s understanding in audio is top notch. We learn many things from him.
It is not silly and I cannot give you a quick answer.What affect more of the sound jitter or sinad? Sorry for a silly question.
I tried changing PLL and there were some noticeable differences. On the lowest setting the sound become diffuse hard to distinguish each musical note but provide big soundstage and high setting sound was crystal clear like musician is right infront of you. Maybe some call it forward sound. I left it on default middle setting.It is not silly and I cannot give you a quick answer.
It depends on the result levels. Harmonics propagation can be much more important than the THD result. There are very limited studies on the jitter audibility.
Om the Pro it seems that coax is a bit better than toslink on 24/192, but at 24/48 the toslink is slightly better than coax. Does that make sense?Let's talk about the jitter over digital outputs. I will use the Holo Audio Spring 3 DAC which is a true NOS DAC and has an unique ability to turn off its PLL. This way I can compare a raw performance of the outputs in j-test.
Ultra, toslink:
Ultra, coaxial:
Pro, toslink:
Pro, coaxial:
Mini, toslink:
Non-WiiM device for a quick comparison, SMSL PO100 Pro, coaxial:
All WiiMs have similar random jitter level, which is reflected by the noise floor, but they differ a lot with the periodic jitter, which is visible as symmetric spikes around the fundamental signal.
A disclaimer, as I didn't mention it yet - all these tests were made with 48 kHz test signal, which is commonly used for jitter measurements. Results may differ for higher sample rates which may be more problematic for toslink cables, especially lower quality ones.
For example, 192 kHz test case on the Pro, toslink vs coaxial:
Another example, 192 kHz again but the Pro vs the Ultra, both on coaxial outputs:
Yes. I've used a random, really cheap toslink cable which can affect results at high sample rates.Om the Pro it seems that coax is a bit better than toslink on 24/192, but at 24/48 the toslink is slightly better than coax. Does that make sense?
a hdg dac making an effort in subjective but also important in "objective-technical"Can you also please show a worst case, Mini at 192 kHz, with PLL turned on, just to check how much the DAC deals with it?
If it’s audible to human hearing then it’s a problem.A bit about jitter and whether we should be afraid of it. I think the video is quite factual, but I don't know if everything is true. There are probably different opinions on this.
