I have an 8-track player using the Line-In RCA inputs. What would be the best Audio Input > Line-In Input Resolution > input resolution to choose?
I currently have Sample Rate: 44.1 kHz and the Bit depth: 16 bits.
I'm curious what happens if you choose something that is not a good match for the source that you have input (aka ... 192 kHz and 24 bits for an 8-track player)?
I played around with the different settings while listening to an 8 track (Doobie Brothers) but didn't notice a big change (maybe subtle).
If you select a higher setting will the Utlra adjust down .... OR ... is it reliant on setting it accurately for the best listening experience?
Thanks,
Curt
Thanks,
Curt
