I can't find the link for the "transformer maniac" tests.It's a low noise SMPS like Allo Nirvana, right?
(like you know well just design that mini or pro we are on a load lower than max 0.5A .. see much less in current use ...)
For example I have a supra 2.5spc power cable to my roksan amp/dac. It clearly made some very positive things to the sound (speed, clarity, detail). The benchmark is the stock cable.Additional: If anyone tells me he can hear a SONICAL difference with a WiiM and a "better" power supply I will congratulate him for his ears. And stay at least sceptic
So, if the question was if ifi bring a listenable advantage my answer is no.
can be tests to do on hdg stax etc dac-amplified headphones and especially on demanding difficult acoustic music etc...Additional: If anyone tells me he can hear a SONICAL difference with a WiiM and a "better" power supply I will congratulate him for his ears. And stay at least sceptic
the small old original non-counterfeit 1A from apple seems a good candidate for this use indeed.. not very expensive and often abandoned at the bottom of the drawers..For example I have a supra 2.5spc power cable to my roksan amp/dac. It clearly made some very positive things to the sound (speed, clarity, detail). The benchmark is the stock cable.
Now, my benchmark for the wiim mini is a 5v apple charger (good as far as measurements, could be better on some metrics) . Apple charger has not something negative. I cannot test ifi at home. So either you want to "hide" that you found sonic improvements or you payed for something comparatively very expensive for no reason.
Possible only if one is faulty or through interactions with another audio components.Additional: If anyone tells me he can hear a SONICAL difference with a WiiM and a "better" power supply I will congratulate him for his ears. And stay at least sceptic
and with powerbank?Possible only if one is faulty or through interactions with another audio components.
That's the Mini FFT spectrum on the analog output when in idle, and quite good SMPS is used:
None of those spikes are still visible when the Mini plays anything, even the dithered silence content:
but the noise floor is much lower, it seems to me.. isn't it?Juste aucun pic affiché en mode veille, c'est la seule différence :
Le même résultat lors de l'utilisation d'Allo Nirvana avec la sortie CC mise à la terre. Et les pointes sont réduites en mode flottant.
Unfortunately no fresh data here.
If it's really genuine and if you're lucky. I have 2 of those Apple chargers, both look genuine. I've measured 460 mV Vpp ripple noise for one of them and 120 mV Vpp for another one.the small old original non-counterfeit 1A from apple seems a good candidate for this use indeed.. not very expensive and often abandoned at the bottom of the drawers..
will give them meaning
mini less of 0.25A
It is the a1400 found inside the iPhone package . You can still buy genuine, they are available.If it's really genuine and if you're lucky. I have 2 of those Apple chargers, both look genuine. I've measured 460 mV Vpp ripple noise for one of them and 120 mV Vpp for another one.
devious observation which allows when to note that the powerbank remains the quietest solution in this case .. but nothing new ..
definitely need to be checked mesured before use.If it's really genuine and if you're lucky. I have 2 of those Apple chargers, both look genuine. I've measured 460 mV Vpp ripple noise for one of them and 120 mV Vpp for another one.
A1400 are quite seldom actually, A2118 became more common.It is the a1400 found inside the iPhone package . You can still buy genuine, they are available.
Nirvana is less noisy than my powerbankdevious observation which allows when to note that the powerbank remains the quietest solution in this case .. but nothing new ..
an interest or not for our wiim.. I don't know...
but confirms the interest of this kind of solution for devices such as cosmos etc.
and now..you need test différents.. powerbank..definitely need to be checked mesured before use.
between counterfeit or bad aging etc.
Why is that?
it seems nice this "old" nirvana..That is what I call a real NIRVANA
But fun in each case!
