- Nov 6, 2022
Hi Team,
I want to jump in and give an explanation on why we need the regular updates -
1. We collect feedback from various users so we need to address their problems with the new firmware. Just so you know, your use case may be a small subset of the features provided by the product.
2. The devices report the exceptions/crashes to our device cloud so we address these exceptions and crashes based on the reports.
3. Our users are physically spread around the globe and we can't reproduce many issues in our lab (i.e., music service issues in certain regions). Sometimes, we rely on feedback from users from particular regions.
4. Streamer is only one component of your entire audio system. Many times, when you observe the problem, it may be caused by your other system component. Taking the pop noise as an example, some DACs can't handle properly the sample rate/bit-depth change between tracks with their optical and coaxial inputs that cause the pop/click noise. We have reproduced this with other streamers that perform the bit-perfect decoding and the problem is gone when using the fixed sample rate/bit-depth output (however, it degrades the audio quality with resampling).
5. Our streaming platform consists of many streaming protocols and music service integration. The SDK and API from our partners are frequently evolving as they'll also continue to fix bugs or provide new improvements. As an example, with the latest Spotify update, you can listen to Spotify podcasts on the WiiM devices now while you can't do that previously.
I hope it helps to clarify our standing on the firmware and App update. I'm looking forward to working with you all to improve these products further. So please feel free to let us know if you have any suggestions or comments. Thank you all very much!
