Saabracer23
- Dec 29, 2024
I received a WiiM Pro Plus from an extremely generous person as a secret Santa gift. What a cool gift. This was my first real streamer. I’ve used it maybe six or seven times so far and it’s been a fantastic piece of equipment. I went to use it this morning and I got an alert of an app update. I started playing music and found I was getting no output from an amplifier I just repaired. I repair and restore audio equipment as a regular thing and I like to use the Pro Plus as an easy method of playing audio. I had just used it a couple of days ago on my main system upstairs to play Christmas music.
Anyways, I thought it was maybe the amplifier I just repaired so I grabbed a CD player and hooked it up and got audio output immediately. Hmmm. I shut down the app and restarted it and play with it for about an hour and could not get any audio output. So I looked online and see that there are others that have had this issue. I checked some of the recommendations like going into settings and making sure analog out was on, check/uncheck the variable or maxed output. Nothing I did would result in audio output.
I did hook it back up with an optical cable back to my main system and used the built-in DAC of my amplifier, swapped the output on the WiiM to optical out and it played music exactly as it should. With it still playing music, I then hooked up a pair of RCA cables back to my main system and swap the audio output to the analog out and silence. Kind of sucks that I was only able to use it a handful of times.
Anything else I should look for? Maybe the internal DAC gave up? Any inline opamps maybe? I don’t have a schematic nor have I opened it up so I don’t know. What should be the next step? Being a secret Santa gift hopefully an exchange won’t be too much work.
I would really appreciate any assistance or suggestions. Hopefully it’s something I overlooked and this one can be returned to working status.
Thank you,
Dan
Thank you,
Dan
