dominikz
Senior Contributor
- Dec 31, 2024
My UMIK-1 came with a USB-C port, and I use it without issue with my Galaxy S23+ with a USB-C to USB-C cable.Thank you. Do you happen to know if the UMIK1 is compatible with the Galaxy S22 using a USB to USB-C adapter?
I guess you might have the older UMIK-1 revision that has a USB-B port instead - but I assume it should work exactly the same with the appropriate cable or adapter.
