Hello,
I'm new here and recently purchased the WIIM Ultra, primarily for my Audio-Technica AT-LP120X turntable. I wanted to use the Phono out and connect it to my Nakamichi Shockwafe 7.2.4 Sound system, transforming my living room into a true entertainment environment. Initially, I connected the LP120X directly to the Nakamichi using the line out from the record player, but the output wasn't satisfactory. Therefore, I began searching for pre-amp solutions and discovered the WiiM Ultra. I was prepared to spend around $300-400 on a pre-amp, and this device caught my attention due to its numerous connectivity and streaming options, offering much more flexibility than a regular pre-amp.
I watched several reviews, and while most were positive, they also mentioned that the Phono pre-amp was the weakest part. Despite this, I decided to give it a try and couldn't be happier.
I'm extremely pleased with how the Phono pre-amp, paired with my Audio-Technica LP120X and Ortofon Red MM, outputs to my Nakamichi. It has brought a new level of dynamic range and overall clarity to my records.
While this setup may not be what some consider true Hi-Fi, as the signal is digitized using the Digital Optical Out, in my opinion, it perfectly complements the Nakamichi system and has tremendously improved the sound of my turntable.
Since my Nakamichi supports 192Khz/24 bit, that's the setting I chose.
Additionally, the ability to use several stages of amplification, including the equalizer and output gains, allows me to fine-tune the sound to my preferences.
Another great feature is the extensive connectivity options this device offers for its price range. I really feel like I hit the sweet spot. One disappointment is the HDMI, which doesn't support eARC, leaving that task to the Nakamichi.
However, I love the possibility of connecting various BT devices to it. Connection-wise, it's very straightforward and user-friendly, with a nice display that allows me to monitor output VU power.
It would be great to have a widget that shows the original versus output power in an analog way, as there is plenty of screen space available for dual VUs.
Overall, I'm very satisfied with the device itself, the sound quality, the amplification stages, options, configurability, design, and ease of use.
Best regards,
