I didn't bet on you, but in this race you turned out to be a dark horseSo the WiiM Golden Ears award goes to a soon to be 70yr old with hearing aids? Maybe need a better endorsement than that![]()
If I did it again, I’d probably give a different answer…I didn't bet on you, but in this race you turned out to be a dark horse![]()
and alcoholOn a serious note, I find blind tests like this very difficult to do and always have. I don’t have very discerning hearing, and it’s only really over a longer period that I decide whether I like something or not - if I quickly get bored with it, it’s not for me. And I’d admit that might well be impacted by external factors, even mood.
Moi? Shurely shome mishtake, hicand alcohol
More like a Golden yEars club.No chance![]()
I tried the puzzle again at home...and with Foobar2000, my desk Audio Interface (RME BabyFace Pro FS) and HD800S headphones I couldn't reliably tell the difference between the 3.With the Pro Plus finally out and in stock in the US, it's time to solve the audio puzzle. Y was the Pro Plus, Z was the Mini, X was my 13 years old DAC.
Who is the winner?![]()
I would say it's either "they are hearing with their eyes" or they somehow manage to volume mismatch between the two tests.Don't worry, you can still attend Golden yEars club
BTW, what to say when you see a statement like audible "day and night difference" between WiiM connected to the DAC via optical and Pi with the Allo DigiOne hat connected to the same DAC?
a "big job" if you want to update your measurements with the normal "modified" version (firmware? or hardware? we never had any clarifications??) and not the beta..New WiiM app released on iOS with selectable DAC filters for the Plus.
I didn't get a new sample so I can only re-measure the old unit. I will test different filters behavior in few days but for selected measurements only.a "big job" if you want to update your measurements with the normal "modified" version (firmware? or hardware? we never had any clarifications??) and not the beta..
Thanks - hadn't noticed that feature hidden under audio output. Wasn't mentioned in the release notes that I could seeNew WiiM app released on iOS with selectable DAC filters for the Plus.
ahhh sorry..I didn't get a new sample so I can only re-measure the old unit. I will test different filters behavior in few days but for selected measurements only.
My standard routine of checking all the optionsThanks - hadn't noticed that feature hidden under audio output. Wasn't mentioned in the release notes that I could see
I'm still seeing cover art playing from LMS to my ProMy standard routine of checking all the options
Alexa language setting seems to be broken. Also no cover art for squeezelite.
Good to know, but neither iPad restart, the Plus nor LMS helps for me. What is your FW?I'm still seeing cover art playing from LMS to my Pro
4.8.527256Good to know, but neither iPad restart, the Plus nor LMS helps for me. What is your FW?
Same as mine. Time to reinstall the app probably.4.8.527256
